Exporting results to excel not working
WufiApprentice
Post by WufiApprentice »
I am having problems trying to export simulation results to excel. I have followed the WUFI Plus manual and everything has worked well, except exporting. I have selected CO2, RH and T for excel export, but when I press the "Excel export" button nothing happens. Do you have any ideas what might be the issue?
Version is a Student License, WUFI Plus V.3.5.0.1,
srinivass
Re: Exporting results to excel not working
Post by srinivass »
Hi there,
I was told that due to issues with Excel export, that feature has been disabled in WUFI 3.5.0.1. The Export to file exports it as .txt file.
Hope this helps.
Shanti
WufiApprentice
If anyone runs into this problem in the future, there is a file in (...\WUFI Plus\WUFI\Tools) called "Load WUFIplus Result Textfiles" which can convert exported text file results to excel. The file contains a button, however when running this I kept running into error "Subscript out of range". Finally I have found there is a wrong number in the macro and two misspellings. To fix this, right click the button and click "Assign macro" and then click "Edit". Replace the code with this slightly adjusted code:
Sub WUFITextdatei()
' WUFITextdatei Makro
Dim datei1$
Dim temp As String
Dim var As Integer
Dim counter As Integer
Dim strCountColumn As String
Dim strCountColumn_ As String
Dim intCountColumn As Integer
Dim intCountheader As Integer
Dim intCountRows As Integer
Dim wb As Workbook
Dim FInfo()
Dim ColumnNames()
Application.ScreenUpdating = False
datei1 = Application.GetOpenFilename("txt-Datei (*.txt),*.txt")
If CStr(datei1) = CStr(False) Then
MsgBox "Please select a WUFI Plus Report-Textfile", 48, "No File selected"
Exit Sub
End If
Open datei1 For Input As #1
Do While counter < 4
Line Input #1, temp
counter = counter + 1
Loop
Line Input #1, temp
strCountColumn = temp
strCountColumn_ = Mid(strCountColumn, 18)
strCountColumn = Left(strCountColumn_, 1)
intCountColumn = Val(strCountColumn_)
counter = 0
ReDim ColumnNames(intCountColumn - 1)
Do While counter < intCountColumn
Line Input #1, temp
ColumnNames(counter) = temp
Loop
intCountheader = intCountColumn + 6
intCountRows = 0
Do While Not EOF(1) ' Schleife bis Dateiende.
Line Input #1, temp
intCountRows = intCountRows + 1
Loop
intCountRows = intCountRows - 1
MsgBox "Reading: " & intCountColumn & " Columns und " & intCountRows & " Rows ", 48, "Status"
' FInfo = Array(Array(0, 1), Array(25, 1), Array(39, 1))
ReDim FInfo(intCountColumn - 1)
For counter = 0 To intCountColumn - 1
If counter = 0 Then
FInfo(counter) = Array(0, 1)
End If
If counter = 1 Then
FInfo(counter) = Array(25, 1)
End If
If counter > 1 Then
FInfo(counter) = Array(((counter - 1) * 14) + 25, 1)
End If
Next counter
Debug.Print "Before opening workbook"
Workbooks.OpenText Filename:=datei1, Origin:=xlWindows, _
StartRow:=intCountheader, DataType:=xlFixedWidth, TextQualifier:=xlDoubleQuote, _
ConsecutiveDelimiter:=True, Tab:=False, Semicolon:=False, Comma:=False, _
Space:=False, Other:=False, FieldInfo:=FInfo()
Debug.Print "After opening workbook"
Set wb = Workbooks(Workbooks.Count)
wb.Activate
wb.Sheets(Sheets.Count).Activate
wb.ActiveSheet.Rows(1).Insert
' wb.ActiveSheet.Rows(1).Insert
wb.ActiveSheet.Range(Cells(1, 1), Cells(1, intCountColumn)) = ColumnNames
wb.ActiveSheet.Range(Cells(1, 1), Cells(1, intCountColumn)).WrapText = True
wb.ActiveSheet.Range(Cells(2, 1), Cells(2, intCountColumn)).Font.Bold = True
' For b = 2 To intCountColumn
' wb.ActiveSheet.Cells(2, b) = Application.WorksheetFunction.Sum(ActiveSheet.Range(Cells(4, b), Cells(intCountRows + 4, b)))
' wb.ActiveSheet.Cells(3, b) = Application.WorksheetFunction.Average(ActiveSheet.Range(Cells(4, b), Cells(intCountRows + 4, b)))
' Next b
' wb.ActiveSheet.Cells(2, 1) = "Col.Sum:"
' wb.ActiveSheet.Cells(3, 1) = "Col.Avg:"
' wb.ActiveSheet.Cells(1, 1).ColumnWidth = 15
Close #1
End Sub
Private Sub Workbook_Open()
End Sub
The changes are on the line "strCountColumn_ = Mid(strCountColumn, 18)" where it was previously 17, causing error. Also at one place "count" was misspelled "coutn" and in another "False" was misspelled "Flase".
