Transfer coefficients
bbarms
Post by bbarms » Fri Sep 28, 2012 9:36 am -1100
I am new to the forum and maybe this has been considered, but I have not found an answer, Under the Surface transfer coefficients box there is the interior (right side) the line for heat resistance is there, however under the discription it says exterior wall and I am unable to change that to say interior wall, is it possible to change that or am I misundersting the line item? I am asking because the question was raised with me.
thank you
Post by Manfred Kehrer » Mon Oct 01, 2012 1:18 am -1100
WUFI Pro should also have the option to select "Partition Wall (inner)" which maybe what you are looking for.
bbarms
Post by bbarms » Mon Oct 01, 2012 1:51 am -1100
Thanks Manfred, That was it thanks, sorry for a silly little question
Bill
