I hope somebody came across this problem in the past.
I installed WUFI 5.2 ORNL as recommended. My computer is Dell, 64bit, Windows 7. I installed the program and the database in the same folder WUFI on drive D:/.. (OS is on C:/ for the reference). The installation process went smoothly -- both the program and database.
However, when I am trying to open the program 'The device is not ready' message pop up (Fig.1). Once I click Ok, 'Access violation at address xyz in module 'WUFI.exe. Read of address xyz.'' (Fig.2), click Ok again. Then, the window -- that is the same as ABOUT WUFY in HELP -- does not disappear (Fig.3). Anything I do lead to 'Access violation..' again (Fig.4).
How do I resolve this issue?
Thank you very much in advance
tags: ORNL, The device is not ready, Access violation at address in module 'WUFI'. Read of address ...
The device is not ready; Access violation at address in modu
- Fig3
- Fig3.JPG (113.74 KiB) Viewed 11406 times
- Fig2
- Fig2.JPG (56.99 KiB) Viewed 11406 times
- Fig1
- Fig1.JPG (78 KiB) Viewed 11406 times
Re: The device is not ready; Access violation at address in
I guess you have 64-bit Office installed. Please try to replace it with 32-bit version of MS-Office. Otherwise the database drivers could not be loaded (WUFI comes with a MS-ACCESS Database which will be replaced by a future version).
Veit
Veit
Thank you very much for the reply. Indeed, you are right -- I have 64 bit version of MS Office. Can I remove just MS Access without removing the rest of 64xbit MS Office? Are there any work around? or must I replace 64bit Office Suite for 32bit one?
Respectfully,
IK
Respectfully,
IK
I don't think so. You will need to replace the whole office suite (http://answers.microsoft.com/en-us/offi ... 36da957dd5)
Veit
Veit
I uninstalled Office and installed 32-bit version. The program still does not want to run -- has the same issue. I re-install WUFI... The same thing. Then, I uninstalled Office again to find out if it was the issue in the first place... the same thing.
I would like to mention another piece of info that is maybe helpful. When I try to close WUFI, the same issue occurs. I have to force it through Task Manager. I am not sure if that helps though.
Could it be the leftovers of old Office in the Registry? Are there any other suggestions for the resolving this problem?
Thank you
Thank you
