In Sept 2013, downloaded and installed WUFI ORNL 5.2 (version 5.2.0.972.DB.24.76). Computer is running Windows XP Pro SP3, logged in as an Administrator.
Successfully can open WUFI application and enter most inputs. However, climate pages (outdoor and indoor) are only partly functional, return error code. Cannot run calculation with film.
Please advise.
Error External Exception C000001D
Re: Error External Exception C000001D
when does this exception messge show up? Already when you switch to climate tab?
In case you encounter similiar problems using outdated hardware (processor does not fully support sse2 instructions) you can use the attached version of a less performant climate library (for WUFI 5.2 and 5.3 only). Just replace the installed version by this one (administrative privileges are required).Computer is running Windows XP Pro SP3, logged in as
an Administrator.
Processor is AMD Athlon XP 2500+ 1.83 GHz, 480 MB RAM
- wuficlimate.dll.zip
- Version 1.0.2.16, built not to use sse2 instructions and without optimization
- (166.75 KiB) Downloaded 1010 times
