Unfired clay brick
rozumjak
Unfired clay brick
Post by rozumjak » Wed Apr 06, 2016 1:13 am -1100
I am working on my master thesis comparing the hygrothetmal behavior of different wall systems and I would like to include a wall made of unfired clay brick (i.e. http://www.claytec.de/produkte/baustoff ... rwerk.html at the bottom). I was going to use the alternative material (clay mortar) but I am afraid that due to the different clay content in those two materials the sorption isotherm (and possibly the other characteristics) might not be representative.
Do you know if the material characteristics of unfired clay bricks have been measured?
Thank you
Jakub
Re: Unfired clay brick
Post by Manfred Kehrer » Wed Apr 06, 2016 1:33 am -1100
I am sure there have been made measurements. May just be hard to get them.
I see in your profile that you use WUFI Light. Thats means even if you get the material properties you will not be able to use them as you cannot change the material properties.
Post by Christian Bludau » Wed Apr 06, 2016 2:09 am -1100
Dear Jakub,
if you like to use a full version of WUFI for your thesis, please sign in to our online shop and apply the wanted version in the menu "student licenses":
https://wufi.de/en/webshop/
Post by Christian Bludau » Wed Apr 06, 2016 2:43 am -1100
Dear Jakub,
i do not have measurements of unfired clay, but see the clay mortar in the WUFI "Masea Database". This may be close to your material.
rozumjak
Post by rozumjak » Wed Apr 06, 2016 5:54 am -1100
Hi Manfred,
I have updated for the Pro version, but did not update my profile here. So this issue is solved.
You say that there are for sure data on this material. Do you have any suggestions which institute could be having it. Is there any other building physics measurement body apart from Fraunhofer and Masea? So far I havent found any paper performing the simulation on unfired bricks.
Thanks a lot Christian for your suggestions. The mortar clay is my back up option.
Jakub
Post by Manfred Kehrer » Wed Apr 06, 2016 6:00 am -1100
Sorry, I have no further information which could help you.
I think a good approach could be to contact all the Labs which participated in the MASEA project.
