Hi all,
I'm a WUFI Passive beginner, I modeled a simple single house using free version of WUFI Passive 3.2 following the manual's instructions as well as available tutorials. However, the program is giving me an error, saying I need to assign rooms ventilation under the mechanical system I created, the problem is that rooms are not showing on mechanical ventilation device tab (as showed in wufi passive tutorial).
Does anyone know what is happening or how could I fix this?
Thank you!
Luciana
Assign Rooms Ventilation Error
Re: Assign Rooms Ventilation Error
And just to confirm there are rooms listed under "Zone"\"Ventilation\Rooms"\"Rooms ventilation" tab?
I am having this same issue. When I go to assign ventilation to the individual rooms, there is no dialog box. I've had others familiar with WUFI look at the issue and they have never had the same problem. Thoughts?
Can you upload screenshots of the error, the ventilation unit assignment tab, and the table of rooms?
That might help to understand the issue...
