Hi Dear,
I have already created the indoor climate file in format of *.wac in wufi. I would like to use this file directly in wufi but when i put the tick of use left climate and i import indoor climate file , i should select again one of the standards of indoor climate.
Finally output result of simulation in indoor temperature and humidity graphs are very different whit my imported temperature and humidity that you can fine them in attachment file.
1. what is the problem?why the graphs are not similar to my imported file?
2.How can I use directly my indoor climate ?
Thank you so much
Samira
indoor climate
indoor climate
- indoor climate.JPG (187.38 KiB) Viewed 12251 times
Re: indoor climate
After unselect "Use Left Climate", did you switch to "Map/File"?
Re: indoor climate
No i did not switch to "Map/File" , it remained on perilously position and it is possible to choose other option.
- Unbenannt.JPG (25.23 KiB) Viewed 12248 times
Re: indoor climate
Use "Map/File"
Re: indoor climate
It worked .Thanks very very much for your help.
- dfg.JPG (90.09 KiB) Viewed 12247 times
Re: indoor climate
Hi
How can I export the indoor climate that I have created in wufi once I define the amplitude and mean temperature in the section "indoor climate"?
Re: indoor climate
For export see here:
viewtopic.php?f=4&t=1116&p=6070#p6070
