IP SI Units Conversion Problem
Ned Lyon
Post by Ned Lyon »
Version 6.3.2 noted some fixing of unit conversions. There is still a problem. If I set WUFI units to IP and then import from the library, I can have bad rounding errors that damage materials. If I import library materials in SI and then change to IP the results are OK. Try this with North America Polyisocynurate Board. When set to IP units at import, there is a back step in the sorption isotherm curve that prevents the simulation run. That dos not occur if the material is imported while in SI units and then converted to IP.
Ned at SGH
Sebastian Boegl
Re: IP SI Units Conversion Problem
Post by Sebastian Boegl »
We'll fix this issue with the next update.
