Start and end water content in building components in WUFI Plus
Posted: Wed Feb 21, 2024 4:45 am -1100
by srinivass
Good afternoon,
I hope you can help. I am trying to determine the initial conditions (RH) for masonry components of an existing building for simulations. I am using the Assign Built-In moisture and In each layer to start with. I need to know the water content in each layer of the building component at the end of each simulation. I cannot see the start and end water content in each layer in the WUFI Plus results currently as in WUFI Pro. Is there a box I need to tick in WUFI Plus for these results to show? Is there any other way to find out the end water content in each layer in WUFI Plus?
Thank you.
Shanti
