I was told that dividing the water content of the OSB in lbs/cf by the mass density would provide a measure of the pass/fail of the OSB. If the product was above 20% then there was too much moisture in the OSB. Who has published that standard and how can I find the publication?
Thanks,
C. Furtaw
Moisture (water) content of wood
C. Furtaw
Charles E. Furtaw, P.E.
This is described in the german standard DIN 68800. Wooden based materials should not exceed a maximum water content. But this is depending on the classification so this maximum water content is from 15 to 21 mass percent.
Enjoy WUFI®
.... It is easy and complex.
Enjoy WUFI®
Lucas J. Hamilton
Charles- the Working Draft Standard 160P by ASHRAE has a great section; 6 Moisture Performance Valuation Criteria that addresses mold growth and while these limits would be a bit (4%) lower than wood destroying fungi, it is a great place to start and fits well with the WUFI outputs. You may need to dump your WUFI data into excel or the like to calculate 24-h, 7 day, and 30 day averages but it makes a very useful tool to evaluate your results.
