Error when adding source from transient txt file
Jonas
Post by Jonas »
When I add a moisture source from a transient txt file I get an error when I click on the OK button (see printscreen).
WUFI version 1D 5.3
regards,
Jonas
Error WUFI.PNG (60.96 KiB) Viewed 66979 times
Re: Error when adding source from transient txt file
Post by Manfred Kehrer »
Hello Jonas,
can you upload the source file?
Jonas
Post by Jonas »
Hello Manfred,
in attachment the source file.
regards,
Jonas
Vochtbron.zip
(86.97 KiB) Downloaded 2245 times
Dear Jonas,
both files work for me. What version of WUFI Pro do you use? The latest is WUFI Pro 5.3.4.
Jonas
Post by Jonas »
Hello Christian,
I have version 5.3.3.1353.
I have also problems with moisture sinks with a monthly negative value. When I try to type the yearly moisture load, the program removes the '-'sign.
regards,
Jonas
Dear Jonas,
can you please update to the latest version of WUFI Pro 5 using the download link you got with your WUFI purchase?
The monthly constant source does not work with negative values. That can only be used as a source, not as sink.
