What happens when we tick the box wind dependent and how Wufi use the heat transfert coefficient value ?
What kind of value we should enter to use with wind dependent. (10 ?)
Thanking you by advance.
Greetings.
Wind dependent Heat transfert coefficient
Dear Raymond,
the heat transfer coefficient will be ignored if you click then "wind dependent" Box, except if the selected climate file on the left side does not contain sufficient data (wind speed, wind direction) to calculate the wind dependent heat transfer coefficient.
