v.2.5.4: influence of checking "explicit radiation balance"
Posted: Wed Jan 28, 2015 10:25 pm -1100
Dear Sirs;
In order to take into account the cooling effect of long wave radiation, checking "explicit radiation balance" gave a apparently overheated interior environment through years.
It was seemed to be caused by the heat gain through window in the componet of "heat flow : exchange with windows".
In the example project, we just assumed a poor single pane window so that It could not keep gaining heat flow to the interior zone through day and night.
Similar numerical results were obtained not only for the climate file of Tokyo, but also for Willmington NC.
In Holtzkirchen we confirmed the similar tendency.
We are wondering if there are any bug report on this issue.
However the mwp file is not allowed to upload with articles in the forum, If you would check the example cases, we could provide them.
Generally speaking, the long wave radiation is seems to provide certain cooling effects, but the result for "explicit radiation balance" case showed the apparently overheated temperature profiles.
