Missing climate data for 'From Map'
ChrisBriley
Post by ChrisBriley »
I'm using WUFI Passive 3.0.0.0 on Windows 7.
When I try to input climate data (for Arlington Virginia) on my Localization tab, I select "From map" hit "Browse" and get an unhandled exception error...
"The Microsoft Jet database engine cannot find the input table or query 'WP_ClimateDataset'. Make sure it exists and that its name is spelled correctly."
How do I load in this climate data file or even find this file, or get this file?
Thanks.
Chris
Re: Missing climate data for 'From Map'
Post by mpazold »
Hello Chris,
have you used an erlier version of WUFI Passive? And for installing WUFI Passive 3.0 was there an error at the end of the installation, was the WUFI-DB.exe delivered with the Install_WUFI_passive.exe in the same folder? This error can occur due to an old Database version.
For the montly climate data, you might contact PHIUS: http://www.phius.org/wufi-passive-tools ... -data-sets
for hourly dynamic climate data you can find addtional information here: http://www.wufi-wiki.com/mediawiki/inde ... ls:Climate
