Initial conditions from file data
Posted: Mon Jul 18, 2016 7:26 pm -1100
Guten morgen fraunhofer person
I am simulating a suspended concrete slab with insulation to the underside.
To determined the starting moisture content for the concrete, I ran a simulation starting at 95%RH/20C for 3 months, then exported the kg/m3 profile data to use as starting conditions for the simulation when the insulation is installed.
Question 1: the only way I can find to use the "profile data" for the concrete and standard "80%RH/20C" conditions for the insulation seems to be to edit the .asc data file and add kg/m3 values for the insulation that correlate to "80%RH/20C" - is this correct?
Question 2: when I do the above, I seem to also have to edit the kg/m3 value for the last mm of concrete because the starting kg/m3 for the insulation reported in the "outcomes report" is much higher than the kg/m3 value nominated for "80%RH/20C"?
