Trouble with running simulations with self-created climate files
Posted: Tue Mar 28, 2017 3:32 am -1100
by sondredl
2017-03-28 16_31_15-Tgr,250 - Notisblokk.png (34.94 KiB) Viewed 8774 times
I've created climate files for a construction against terrain. I've used the document "createclimatefile" in exel and converted it to a wac-file. The files looks good when i import them into WUFI. It also works running simulations, but there are no changes in any parameters. So temp, humidiry, water content .... in the construction are constant. The simulation works if i use a climate file which follows the program, so there is no problem with the model.
So i was wondering if can check out the climate file which is attached, and see if there is any errors.
Best regards, Sondre Lund
Re: Trouble with running simulations with self-created climate files
Posted: Tue Mar 28, 2017 3:39 am -1100
by Manfred Kehrer
Likely your transfer coefficients are zero
