Hello, i am relatively new to WUFI 2D although I have worked quite a bit with 1 D simulations.
I have a wall section where i have board material that is user defined. When i try to process the model i get an error.
The error reads:
error in initial condition:
File 20 not found
Switch module to edit that property?
I switch back to correct the error. I have 20 degrees for temperature and 0,8 for RH. I am not sure what the error is linked to as i can only change the temperature and RH in initial conditions.
Thanks for your help!
CSFT
Re: error in initial condition
Dear CSFT,
go to the initial conditions.
The position where you entered 20 and probably also 80 is over scribed with "from File". So there WUFI wants initial conditions from file and does not find the given file name "20".
The changes you want to apply are done in the table below.
