WUFI Simulating Weather Data
Posted: Tue Nov 07, 2017 5:26 am -1100
by Alina0826
Hello :
I have three questions related to WUFI simulating weather data:
1. Weather Data read from file: In this case, if I only import one-year weather data into WUFI, but the simulating period set to for example three years. Will wufi repeat the import weather data to three year?
2. Weather database: Weather data in database is real data for every year? What's kind of data built-in WUFI.
3. WUFI result (for example: MC): It always has a strong vibration at the beginning of the simulating period, and become stable after sometimes. What cause this phenomenon? Weather data?
Look forward to your response.
Thanks!
Re: WUFI Simulating Weather Data
Posted: Tue Nov 07, 2017 5:50 am -1100
by Manfred Kehrer
Hello Alina,
Yes, WUFI will read the same climate file over and over again. I presume you talk about WAC format. Be sure the data are starting with Jan 1st. 1 am, hourly and contain 8760 datalines.
Depends on which country: For USA, Real data for one year are built in. Selection are 10% warm and 10% cold year out of a 30 year period. ASHRAE labeled climate files please look up ASHRAE RP1025
If you use the same climate file over and over again you necessarily will end up in a stabilized yearly condition at some point.
Kind Regards,
Posted: Wed Nov 15, 2017 6:25 am -1100
by Alina0826
Hello Mr.Manfred
Thank you very much for you reply!
Just for Quota 3, I still have question.
I can see the stabilized conditions you described. But I cannot understand the vibration at the beginning of the simulation, especially after I set the initial condition using real-time data.
I want to ask why it has the vibration from very beginning for most of models. Could you please explain the principle for that?
Thanks again for your help!
Posted: Wed Nov 15, 2017 6:29 am -1100
by Manfred Kehrer
If you use the conditions at end of calculation (=stabilized) as the initial conditions, you won't see the vibration
Posted: Thu Nov 16, 2017 9:48 am -1100
by Alina0826
Thank you for your help!
Posted: Tue Dec 05, 2017 10:07 am -1100
by Alina0826
I have a further question.
How to understand "10%-coldest and 10%-warmest year out of a 30 years period"?
It will combine the weather in different years? If so, which month uses 10% coldest year data and which month uses 10% warmest?
Thank you very much!
Posted: Tue Dec 05, 2017 10:57 am -1100
by Manfred Kehrer
You just rank the 30 years by average temperature and and take the 3rd and 28th
Posted: Wed Dec 06, 2017 12:01 pm -1100
by Alina0826
Thank you for your reply!
I still cannot understand your sentence very well.
What you mean is rank 30 years(from which year to which year) and take the 3rd place and 28th place to combine?
