Page 1 of 2
Graph for WUFI 2D
Posted: Thu Jul 05, 2007 9:42 pm -1100
by RAJI
I am currently working on WUFI 2D and I can't manage in visualising graph. I mean that I have no problem with WUFI2DViewer but I would like to analyse the results, and therefore visualise the graphs of the temperature, HR... in the wall. If I launch the result viewer(1D) I only can see the water content, more precisely the evolution of the water content in the time, but I don't know at what point of the wall it is. I can't change those things.
If I try to open a Wufi result file, I have the same problem, only a graph of water content appears.
Moreover, is it possible to export the data in a xls file to use excel ? or at least in a txt file that I can convert in a xls file.
S. RAJI
Posted: Thu Jul 05, 2007 9:49 pm -1100
by Manfred Kehrer
Dear Mr. Raji,
we Had some bugs in the first Release of WUFIGraph. The latest Version of WUFIGraph is 2.4.7. You can see it in the dialog title.
Please reply if you have an older one one and I will send you the patch.
Best Regards,
Posted: Thu Jul 05, 2007 9:52 pm -1100
by RAJI
The version I use is V 2.4.5
Posted: Fri Jul 06, 2007 3:00 am -1100
by RAJI
Thank you very much for the patch, now Wufigraph works well.
But I still can't export a project. It does'nt work.
Thansk for the help
Exporting data from WufiGraph
Posted: Sun Jul 08, 2007 6:55 pm -1100
To export data into an ASCII-File mark the diagram on the left side and choose the menu "Current". There you can find the option export.
Another easy way is to do a right mouse button click on the diagram you want to export and choose export.
Results
Posted: Mon Oct 29, 2007 3:26 am -1100
by bhschoenbauer
I am having this same problem with the results. I also am using the 2.4.5 version and need the update. Thanks
Posted: Thu Jan 24, 2008 10:14 pm -1100
by Rupert
hello, I'm also using v 2.4.5, please send me the current update. Thanks
Posted: Mon Feb 09, 2009 4:11 am -1100
by ID
I'm also having the same problem with version 2.4.5. Could you please send me the update. Thanks
WUFI Graph 2.4.12 w/ Jxpinstall 6.0.180.79 ... a trouble
Posted: Mon Mar 01, 2010 3:01 am -1100
by hs
Hello There.
I recently updated Jave Platform SE Binary of 6.0.180.79 by the automatic
request issued by WUFI Graph 2.4.12.
After the update of Java, I could not terminate WUFI Graph w/o invoking the process manager of Vista and select forced termination.
I am waiting for your sugestion to overcome this troubl.
Thank you in advance for your cooperation.
Hideki
Posted: Mon Mar 01, 2010 3:04 am -1100
by hs
I should notify the Vista status.
Vista Ultimate SP2 and 64bit version.
hs
Posted: Mon Mar 01, 2010 10:25 am -1100
by veitner
Hello hs,
we will setup the mentioned OS-Version and configuration asap.
Veit
Posted: Mon Mar 01, 2010 10:03 pm -1100
by hs
Thank you for your prompt reply.
Besides the trouble I reported above, I should notice the additional trouble of Wufi2D.
In the same OS circumstance, I could not quit Wufi2D normally.
If I selected quit Wufi2D, a window reporting an error message
of "Runtime error 216 at 00404616." poped up and I should push
"OK" button.
I have checked both troubles are just occurred on Vista Ultimate 64bit SP2
situation and it does not happen under Vista Ultimate 32bit SP2 machines.
Any countermeasures?
hs
Posted: Wed Mar 03, 2010 2:27 am -1100
by Antoine
I suffer the same problem.
When I quit wufi 2d, I have the same error.
I use Windows 7, 32bits.
regards,
Antoine
Runtime Error 216
Posted: Wed Mar 03, 2010 8:08 am -1100
by veitner
This is caused by the help system and has been fixed.
The update and bug fix list for the updated version is in process and you should get a notification about the availability of the new version soon.
Veit
Trouble saving
Posted: Thu Apr 14, 2011 10:17 pm -1100
by manexi
Hello.
I've been running some calculations now and I just encountered a tedious problem with WUFI Graph 2.4.12
Every time I try to save a modified graphic project, an error message saying "null" apears and I can't modify it. So I gues for now I'll have to do all the analysis in one go so as to save the graphic project only once, but it would be nice to be able to modify a graphic project.
So, can you tell me if this is my computer messing with me or if it's a bug?
Thanks!
