Saving File with Weather and Materials
Mark Jimmy
Post by Mark Jimmy »
I was wondering if it is possible to save a WUFI file such that both materials and weather files from the personal database are saved within the .W6P
Cheers,
Mark
Re: Saving File with Weather and Materials
Hi Mark,
the material data from all materials used in the component assembly are saved in the project file *.W6P. Weather files can not be included, however. If you want to keep them together with the project file for later reference, you may create a ZIP archive or something similar.
If you have created a user-defined material which you want to re-use in later projects, you might consider writing it to a user-defined catalog in the material database. (Future updates of the material database will preserve any user-defined materials.)
