Is it possible to add ducts to a location outside the conditioned space (e.g., attic) by somehow:
-Adding a small amount of air exchange (duct leakage) when space-conditioning is called for
-Accounting for duct (and insulation) surface temperature, which would be dependent on space-conditioning schedule
Essentially, I want to account for the heat/coolth and additional moisture added to the attic from these ducts.
I could create rectangular ducts in SketchUp if necessary, but this would still not address the schedule of space-conditioning or conditions within the ducts. Do I have to run the simulation and then use the outputs of the HVAC runtime to create this new schedule? Any simplified methods?
Adding ducts to unconditioned attic
Last bumped by zekk828 on Mon Jul 13, 2020 10:40 am -1100.
