Saturation vapor pressure formula
DAPA
Post by DAPA »
I would like to know the formula for calculating the saturation vapor pressure used in WUFI.
I don't see the vapor pressure in indoor and outdoor atmospheres as output from WUFI.
Thanks in advance for the reply.
Re: Saturation vapor pressure formula
Hi DAPA,
please see here:
WUFI: Sättigungsdampfdruck - Saturation vapour pressure
(scroll down for the English version).
DAPA
Post by DAPA »
Thank you Thomas.
I need saturation vapor pressure formula because I try to simulate the EN ISO 12572 test method (Determination of water vapour transmission properties — Cup method)using WUFI Pro.
I try it on several materials but I found a difference between the vapor diffusion resistance factor of the material choosen from the data base (dry cup) and the vapor diffusion resistance factor calculated by WUFI Pro.
Temperature 23°C
HR 0% / 50% (delta p = 1406,81 Pa)
Heat resistance = 0 for exterior and interior surfaces
Material : ISOVER GW Integra ZKF - 035
Thickness : 14 cm
Water vapor diffusion factor from the data base : 1
Vapor diffusion flux calculated by WUFI: 1.96086E-0006 kg/(m.s)
Vapor diffusion resistance factor calculated : 1,0158
Could you explain this différence of 1,6 % ?
Dear Daniel,
this is because WUFI uses a slightly different version of the formula for the vapour permeability of air than EN ISO 12572. The formula used by WUFI is
δair=1.968e7(ϑ+273.15)0.81P
δair: vapour permeability of air, kg/(m s Pa)
ϑ: temperature, °C
P: barometric pressure, Pa
For
ϑ = 23 °C and
P = 101300 Pa (the default pressure used by WUFI if no other pressure is specified via a climate file),
we have
δair=1.951371010 kg/(m s Pa).
The saturation vapour pressure formula gives us psat=2813.62 Pa.
These data result in the μ-value
μ=ΔRH  psat  δairg  d=0.5  2813.62  1.95137  10101.96086106  0.14=1.000001
DAPA
Post by DAPA »
Dear Thomas,
Thank you a lot for your answer.
It's perfect now.
