Hi all,
I'm not able to search the forum at the moment due to "high server load" so apologies if there is another post covering this elsewhere.
When exporting a passive house verification report to either PDF or DOCX the images in the report are scaled down by about 50% from what they should be. This is something I've been living with by manually adjusting the images after export in MS Word. It would be a big time saver if WUFI would export report images scaled properly without needing to manually adjust all of them. See attached screenshot.
I'm using WUFI Passive 3.3.0.2 on Windows 11 on a virtual machine run in Parallels on OSX 13.4.
Thanks!
Export Image Scaling
- Screenshot 2023-06-20 at 3.19.16 PM.png (209.62 KiB) Viewed 84250 times
