Backsave to Previous Version
Posted: Thu Aug 24, 2023 3:35 am -1100
by hbreaux
Is it possible to backsave a WUFI file to a previous version of WUFI Passive or is there some method for older versions to open files saved in the latest/newest versions?
I use the latest WUFI Passive version, but I have a colleague that uses an older version and it appears they are not able to open files saved in my version.
Thanks!
Re: Backsave to Previous Version
Posted: Wed Oct 11, 2023 4:54 am -1100
by mpazold
unfortunatelly it is not supported. Project fiels are only backward compatible, so newer version can open older files.
However, there is a unsupported chance to open files from a newer version in an older version. In the Save form you can change the filetype from *.mwp to *.xml . So you can save your file in the newer verion in xml and try to open this in the older verison. But, BE CAREFULL and cross-check input and results, there is no guarantee the that input is loaded correctly in the older version...
