Steady State Vs Transient U-Value readings
Posted: Mon Nov 20, 2023 12:11 am -1100
I'm testing a range of cavity wall constructions under both typical conditions and also high moisture conditions (walls facing towards driving rain etc).
All the calculations have 0 convergence errors.
When I compare the "Total thermal performance" steady state U-value in the component section, with the transient U-value readings via the "Thermal Transmission" post processing tool, I have some unexplained readings.
I assumed that for constructions where high levels of moisture are observed, that transient U-values would be higher than the steady state U-value for the same wall construction. As more moisture within insulation typically means a higher thermal transmittance.
In some cases (but not all) where moisture risk is observed, the transient U-values during winter months are in fact slightly lower than the steady state U-value for that same wall construction.
The wall constructions are insulated timber frame with masonry cladding and a slightly ventilated exterior cavity.
I have simulated the exterior wall cavity with an air change rate of 1ACH, could this air change rate have an impact on the unexplained transient U-value readings? Or is it something else I haven't considered?
Thank you.
Thank you.
