Basement modelling
Jwfwilson
Basement modelling
Post by Jwfwilson »
I have been working through some case studies since completing the training in June this year. One example I am looking at is a basement wall scenario.
Using the guidance in "Handling of Typical Constructions" tutorial sheet I have set an external climate using a sinusodial curve and set a external RH at 99%.
When I run the calculation I get a message saying that i have assigned an indoor climate to the left hand side. My sinusodial curve is definately assigned to the left-outdoor climate. Could anyone advise if this is just a double check in the software or am I doing something incorrectly?
Thanks, James
Re: Basement modelling
Hi James,
This is just an indication that there is not an external climate assigned on the left side. You can ignore this if that is wanted.
