Air Layer Errors
ADavis
Air Layer Errors
Post by ADavis »
Recently I have been experiencing some errors when I use the air layers from the material database. I recieve the following message:
Material: Air Layer 70mm
Material Function: Thermal conductivity, moisture-dependent. water content greater than allowed (see porosity)..
I am running a new install of WUFI Pro as of 1 March 2011, and had no initial problems of this type. I have even uninstalled and reinstalled the software in case it was not a clean install.
Can anyone advise on this issue? I have reviewed a previous thread stating that this is an outdated material database, but as my software version is the latest and greatest, I can't sort out what the issue is.
Please help!
Thank you!
Post by Daniel »
Dear Aaron,
there is a wrong setting of the moisture dependent heat conductivity – please unlock the material data and delete the second line. Then you can start the simulation.
Sorry for this problem.
