Solar protections and solar masks
WUFI-
Post by WUFI- »
Hello !
I'm trying to model solar protections and solar masks for a house.
Is there a more accurate way for modelling solar mask (closes ones and distances ones) than using the "reduction factor shading" ?
Thank you for your help,
Laurent
Re: Solar protections and solar masks
Post by mpazold »
a new feature calculating the shading on components depending on all the other 3d-components and the position of the sun is under development.
WUFI-
Post by WUFI- »
Hello !
I install the new WUFI Plus 2.5.4.0.
The IBP support told me that with this new update an option is introduced for calculating shadows depending of sun position and 3D object.
This option is available in "conponent->surface->thermal->calculate shading from all elements.
However, I can't see the new option "calculate shading from all elements".
Can someone help me ?
Thank you !
Post by mpazold »
it is still under development and in the validation prozess. I will send you a PM.
Matthias
