Use the WUFI 2D - project-sources, but it doesn't work, whatever how I operate. Do you have same example about the adding sources?
The button "View Report" doesn't work to, when I click, it shown "This document does not associated with the program to perform the operation".
Except your answer, thanks.
How to add sources and can't output view report
Re: How to add sources and can't output view report
Hello Sharon,
to add a source do a right click in the area below the grid window.
Help can be found here:
https://wufi.de/en/service/downloads/
have a look onthis files:
How to add sources and sinks in WUFI 2D
Determination of source strength
To view the report, the xml-files has to be associated with IE vor example. You also can go to your project folder and open the file wufi2d.xml in Internet Explorer or another program which is able to show xml files with corresponding style sheets.
Thanks a lot, your answer is perfect!
