Error WUFIGRAPH
GlennDeMeersman
Error WUFIGRAPH
Post by GlennDeMeersman »
when I try to open my WUFI2D results in WUFIGRAPH, I get the following error message:
Error
Conversion = '\'
Wufi graph used to work, the error started after I saved a WUFIgraph project
I'm running version 2.4.12 of WUFI graph
Sincerely,
Glenn De Meersman
Post by Daniel »
sent you a PM
Wirbel
Post by Wirbel »
I have the exact same problem. Can you help me ?
Thank you,
Please download the actual version WufiGraph 2.5
There are a couple of problems fixed.
http://www.wufi.de/download/WUFIGraph.zip
pbarkin
Post by pbarkin »
Hi Christian,
I am in the middle of a project and am interested in trying 2.5 out. After I install 2.5 is it possible to switch back to 2.4.12?
What are the other differences between Wufi Graph 2.4.12 and Wufi Graph 2.5, ie: do the the same template files work in both versions etc.?
Thanks!
PB
Hi PB,
you will not need to switch back to 2.4.12.
In 2.5 we corrected a couple of problems existing in 2.4.12, e.g. saving problem and so on. All the templates will work.
Theoretically it is possible to switch back... Just uninstall Wufi 2D and then reinstall the old version. But its not necessary...
