indoor climate
xuzhirui24
indoor climate
Post by xuzhirui24 »
How can I use wufi5.1 to set the indoor temperature and humidity according to the practical conditions, not the only the standard.
in Wufi Light you only can assign the conditions from the standard.
The full version of Wufi Pro allows you to use your own data, for example measured ones.
In the program folder of "IBP-Software" you can find the "Tools" folder. In here there is a excel-file called "CreateClimateFile.xls". This file contains two sheets, one is called WAC, thats mainly for exterior climate and on is called KLI, thats easier to use with measured data. Just leave the unused columns empty... You can import this climate in Wufi by choosing Map/File -> Browse -> User defined file in the climate conditions window.
Hope that helps,
