I need some help with the output of WUFI 2D.
the online help does not works. (perhaps because I have a test version?)
how does the output works?
how can I define the exact place at the construction f.ex. to see the surface temperature...?
thanks
M.Alb
output
unfortunately there is no help for Wufi-Graph at the moment.
But it is quite easy. Just choose "New Page" in the menu bar. There you can choose what output to do. You will get a window with your construction, in which you can choose the wanted grid element.
The blue grids around the construction keeps the boundary condition.
Hope that helps,
Hope that helps,
