moisture fluxes
edgararq
moisture fluxes
Post by edgararq »
Is there in WUFI ORNL an option to measure moisture fluxes at key points or at the interface of two layers for determined periods of time?
Kind Regards,
Edgar.
Re: moisture fluxes
Hello Edgar,
the fluxes can be exported via ASCII-Export. That is not possible in the free versions.
You can display the courses in the result graph viewer.
