Is there a way to access WUFI results using an external program, say Matlab?
Thanks!
Accessing WUFI results with MATLAB
Re: Accessing WUFI results with MATLAB
in WUFI Pro you can export the results to a text file, using the ASCII export dialog (menu "Outputs" -> "ASCII-Export..."). This text file can then easily be imported into your favorite data analysis software.
