.WAC file with Imperial units
selder
Post by selder »
Is there a way to use imperial units within a custom .WAC file?
Or is I use SI units for the .WAC will the units correct themselves when imported to an analysis done using Imerial units?
I'm only looking to use the interior temperature and RH.
Re: .WAC file with Imperial units
Hello selder,
the wac-file does not support IP units, you have to transform the values to IP.
selder
Post by selder »
Thank you.
It seems I can use SI in the .WAC file and will work fine when imported to an alaysis using Imperial units.
I also assume the RH number is the same for either.
so, if I want 72 degrees F with 60% RH I could use 22.2 C with 60% RH in the .WAC.
Yes?
Yes, thats right, the wac file can be used for the calculation in IP.
