Exporting results in WUFI Plus - export tab missing
run3
Post by run3 »
The instructions for how to export results to excel are nice and clear - just go to the tab "Report: Data & Results" and select the export tab - but how on earth do you do that when there is no such tab there? In the pictures in the instructions there are 3 subtabs, "Results: Data, Results", "Graphs" and "Export", in the file I've got after simulation the two first ones exist but not the "Export" tab? So what's going on? What can the reason be and how do I access my results (apart from just looking at them in the graphs)?
Sorry, found it! I was looking at a specific zone, looking for the reults for just that one, while the export tab is found under the case! Problem solved & I'm happy! :D
Re: Exporting results in WUFI Plus - export tab missing
Post by mpazold »
Yes, the export Tab only appears under the "Case" - Treenote. Not if you have selected a specific zone.
Additional, if you store the results of an component
(click on a component in the poject-treeveiw - and then to the tab Report:... and check "Retain calculation results")
you can export all the results of this component.
