simulation error : the simulation diverge
Pbourdoi
Post by Pbourdoi »
Hello Wufi support !
I have tried to investigate a simulation of a brick wall without insulation (see file attached)
After the calculation, i checked the temperature surface of the interior wall, and after few month the temperature is higher than 5000°C !
I changed some parameters, expecting to avoid the problem (grid, initial conditions, materials) but it didn't work.
Do you have any idea on how i can solve my problem ?
Thanks for your answer !
Pierre B.
test.zip
(221.14 KiB) Downloaded 653 times
Re: simulation error : the simulation diverge
Hello Pierre,
I think you have probably a problem in your climate file. Please check the file traphour.wac. As far as I know that is no climate from the WUFI DB.
