Climate data error
Seong Jin Chang
Climate data error
Post by Seong Jin Chang »
I have been using WUFI Pro 5.3.
I have a problem about climate data.
I got WUFI climate datas through the Passive House Institute Korea (PHIKO).
These are all wac file. but some of the file has not been run.
I want to know about why this is not done.
I have attached the three files.
1. Photo of error when not running.
2. Executable file.
3. Non-Executable file.
Admin: File deleted!!!
Re: Climate data error
this is a problem in the header. If you open your file in an editor, you can see the following for your files:
executable one: WUFI®_WAC_02
non-executable one: WUFI?WAC_02
unfortunately there was used a special ansi sign for the header. You have to copy over the header line, or replace the ® by an "a" for example:
WUFIa_WAC_02
Then it will work.
The file has to be encoded in ANSI, UTF8 or other will not work.
