Hello Wufi Team:
I am working on my Master thesis about attic ventilation.
I want to import field measurement weather data to attic area, which is hourly data from 2013 to 2015.
While when I check tutorial of design condition about optional climates, which is only one day profile.
Is it possible I import the two year data to weather profile?
Thank you~
Import Field Measurement Weather Data to Attic Area
Re: Import Field Measurement Weather Data to Attic Area
Alina,
a search for CreateClimateFile.xls in this Forum results in dozens of hits which may help you.
search.php?keywords=createclimatefile.x ... mit=Search
Enjoy WUFI®
.... It is easy and complex.
Enjoy WUFI®
What I mentioned is this interface, do we have a sample for attic ventilation
- WUFI Plus.JPG (58.39 KiB) Viewed 12707 times
you might can regard the attic as attached zone with pre-defined climate conditions.
At first you can define the 'extern climate data' file structur ( in the Project tree: 'Fiels/Measured data'). Then you can define this file as optional climate data and then use this optional climate data for the attached zone.
Most of it is shown in this movie:
https://www.wufi-wiki.com/wufifilme/Plu ... d_Data.mp4
