I need to simulate a case of a common wall between two dwellings (with different climates), with an air layer between the 2 walls, ventilated with exterior air.
When i ask to ventilate this layer, I can chose the right or left climate to ventilate, but I would like to use a third one (exterior one). is it possible ?
Thank you for your answer.
François
Exterior ventilation of Air layer in a Common wall
Re: Exterior ventilation of Air layer in a Common wall
Hi François,
no, that is not possible in WUFI Pro. You could do that in WUFI 2D, but you will need to assign the climate to use on some boundary in your construction.
