Dear WUFI team,
Can you please tell me if it is possible to extract ASC or ASCII - File of Heat and Moisture Fluxes from WUFI Pro 6.2, and how could I do that?
I see that WUFI-Graphs only gives a printable option of those graphs but seems like the data cannot be extracted.
Thank you very much,
Marko
Heat and Moisture Flux - WUFI Pro
Re: Heat and Moisture Flux - WUFI Pro
Hi Marko,
you can export the heat and moisture fluxes directly from WUFI Pro.
See Outputs -> ASCII-Export.
The header and format for the output can be set in Options -> Export Format
