3D Thermal Bridges - PSI factor calculation for french Thermal Regulation
FBC
Post by FBC »
Hello community,
I would like to know wether or not it's possible to determine conventional PSI factor for the french regulation using WUFI Plus.
For those who are not familiar with it, the PSI factor consist in the difference of heat flux between a construction with/without thermal bridge.
I thought that, using 3D object, we should be able to do this calculation, but i can't figure out how to get the specific values associated with the thermal bridge itself.
Last, the software as to comply with NF EN ISO 10211 in order to be used within french regulation. Is it the case ?
Please let me know if this is possible and how.
Many thanks in advance,
Cyril
