Wufi Plus - 3D Object: Climate and orientation
btga
Post by btga »
Hello everyone,
I have three questions about 3D Objects in Wufi Plus:
1. About climate as a boundary parameter: There is a "climate" among the boundary parameters. Is it the climate/weather data that we assign for whole building simulation in "case/building" section.
2. About orientation: Does Wufi Plus - 3D objects consider the orientation of the 3D object? For example is it possible to compare the surface temperatures of a north and south facing walls? I have noticed that in the whole building simulation section (case/building) the y axis is reaching from South to North, and x axis from West to East. So, if i order the layers in 3D objects in this logic can I model (external) walls with different orientations?
3. About explicit radiation balance: At whole building scale, I ran the simulations with "Explicit radiation balance on extern surfaces", is that taken into consideration by Wufi for 3D objects?
Thanks in advance!
