I am calculating the roof of a car garage (Sine curve, mean value 12 degrees Celsius in winter). Component - MW thermal insulation on OSB, without vapor barrier and top layer waterproofing with Sd 140m, without infiltration flow. After the calculation, it turns out that the amount of moisture under the waterproofing bitumen membrane rapidly increases to over 400 kg/m3, which in my opinion is unrealistically high and straight. The question is (1) can it really be so (2) where to look for the error, if it is still too much?
Andris
Garage roof
Garage roof
- Component
- Screenshot_8.png (9.11 KiB) Viewed 21921 times
- water content in MW top 10 mm
- Screenshot_9.png (54.21 KiB) Viewed 21921 times
Re: Garage roof
Hi Andris,
please check, if the balances are ok. Looks like you have problems with the convergence. That might be caused by condensate forming in the outer insulation?
