Hi, I am starting up with WUFI light. But as far as I can se there is no climatfile, even not for Holzkirchen.
Would be greatful for some help.
Bjarte
Climatfile Wufi light
Re: Climatfile Wufi light
Dear Bjarte,
one climate file is installed depending on the region you choose for installation.
For Norway that should be Trondheim.
I`v tried Trondheim (Værnes) as well wich has a yellow mark at the map. The other dots are grey.
But I still get the message that there is no Climatefil for the choosen area.
B
B
There are two different stations there, Vaernes and Trondheim. Please zoom into the map (hold the left button and draw a box from upper left to lower right). Then you can select Trondheim.
That was it, thank you
B
B
