Hi all,
i am looking for a way to export data from wfd files to text files for further processing with Perl/Matlab.
I already found the Java tool that is mentioned several times in this forum:
I only have trouble downloading it from the given address. The file can't be found..
Is this a Problem on my side, or can you give me another download link, an updated Version of the Java file, or anything else to conveniently extract the simulation results for script based processing?
Thanks!
Cheers, Bernhard
Java script for data export
Re: Java script for data export
I'm sorry. That server has been updated and the file got lost.
You'll find it attached.
Veit Eitner
Veit Eitner
- wufi2dfiledata.tar.gz
- (12.66 KiB) Downloaded 828 times
That was fast, thanks a lot!
Cheers Bernhard
Cheers Bernhard
Hi again,
i'm kinda stuck with the java code ... I've done some programming, but i've got no particular clue of java..
I have the JRE installed, but I can't manage to compile or execute the code.
Would you mind uploading the example and the little java doc mentioned in
http://www.wufi-forum.com/viewtopic.php?f=15&t=605
again? Probably they'll answer my questions. It seems like they got lost, too..
Thanks!
Cheers, Bernhard
Thanks!
Cheers, Bernhard
again?
- WUFI2D-FileData.tgz
- (23.89 KiB) Downloaded 653 times
- doc.tar.gz
- (815.05 KiB) Downloaded 633 times
Perfect, thank you!
