Importing building geometry using gbXML Import
Is there a way to add windows to the conceptual mass for gbXML export so that they don't make the wall break up into triangulations? I've drawn the windows onto faces in the edit mode and they look fine in Revit, but when I import into WUFI the wall faces are broken at window corners.
Re: Importing building geometry using gbXML Import
The WUFI PLus gbXML import doesn't edit, or check (in detail) the geometrie of the imported gbXML model so far. It might interprets some model geometrie information differnt then the export tool. I will send you a PM.
