WUFI Plug in with SketchUp2015
junelee
Post by junelee »
I have WUFI plus v.2.5.4.0
and trying to plug in with sketchup 2015 but, it is not working.
Is it because the sketchup version is higher than sketchup2008?
Is there no way that I can plug in with sketchup 2015?
Thanks.
Re: WUFI Plug in with SketchUp2015
Post by mpazold »
can you specify what is not working? the installation?
WUFI Plus 2.5.4.0 and 3.0.0.0 should work with Sketchup 2015.
The way to install the plugin is equal in version 2.5.4.0 and version 3.0.0.0, so the latest user manual, chapter 6.1. might help: https://wufi.de/de/wp-content/uploads/s ... us_3-0.pdf
make sure to type in the correct path to your sketchup plugin folder and you need administrator rights to install it.
