Export assemblies OR update sketchup geometry
All about WUFI Passive
ChrisBriley
Post by ChrisBriley »
I have a WUFI model to update. I've created a new wufi file from the new sketchup geometry, but what I'd like to do is either:
A) in my existing wufi model, update the sketchup geometry to my new sketchup file or
B) import all my assemblies from the existing wufi file into this new wufi file made from my new geometry.
Surely this must be possible?
Re: Export assemblies OR update sketchup geometry
Post by mpazold »
A) should work. if you only have changes the geometrie, some dimensions in sketchup, you can load it for the existing file. Opend the old WUFI Passive Project file and afterwards the new sketchup geometrie. The project settings of the old Projects file should not be overwritten.
B) not at the moment. I recommend to design assemblies, materials, time-periods, etc. always in the database (int the top menu bar) and then select it for the actual project.
