Excluding Temperature Dependency in Latent Heat of Evaporation
Swami
Post by Swami »
I can not find reference to this particular check box in the WUFI help; does anyone have an explanation for the choice "Excluding Temperature Dependency in Latent Heat of Evaporation"?
Thank you,
Re: Excluding Temperature Dependency in Latent Heat of Evaporation
Hi Swami,
originally, WUFI used a constant number for the latent heat of evaporation (2500 kJ/kg). Later, the latent heat was made temperature-dependent, but you can switch back to the constant value by excluding the temperature dependence.
Swami
Post by Swami »
Ah makes perfect sense. Thanks for the clarification!
